dm800hd fan issue
  • shae0191
    • 46
    dm800hd fan issue
    Hope someone can help here. I have just bought what was supposed to be a good working condition dm800hd sim 2.01 which i believe to be the older version of my dm800hd pro 2.10. on inspection i found it to be very poor condition(old bootloader 75,broken remote,screws missing but two,build up of grease inside and a burnt out fan which i believe the grease to be the suspect. Well i took my fan from my pro and put it in the box that i just aquired and the fan is racing at high speed and i just do not know why this is.vsually everything looks fine after cleaning all the inards and loading new software but this fan is doing my head in now. i have a replacement on the way so i can get both up and running but does anyone know how this is doing this and can anything be done to slow it down. Help is once more needed please.
  • Rodbouy
    • Jul 2010
    • 1320
    Just disconnect it and stick a notebook cooler under it. The fans are pish.
    • nice guy
      • Jan 2012
      • 11
      Me to have fan problem with dm800hd...The fan was very noisy...i changed that and after a month again same problem....I bought a laptop cooler from ebay and that one was the same...very noisy from beginning and the fan doesnt shut down when the box are off. Now i dont have fan at all....using without fan because very difficult to find any good fan......
      Anyone who have idea where two buy any internal good fan or laptop cooler which one no led lamp please and the fan can shut down when the box are off. which seller on ebay????????
      • Fergal
        • Aug 2008
        • 1007
        Post 22 might help or any of the other solutions in the thread
        • Simba92
          • Nov 2011
          • 134
          You could mod the USB laptop cooler, chop the usb off and replace with a scart. Then it should turn off when in standby.
          • lombard
            • Aug 2008
            • 793
            Hi, i got a better mod,
            get one of these
            3.5 80mm HDD Hard Disk Drive Single Cooler Cooling Fan with 4pin Molex Connector | eBay
            chop end bit, also chop the wire connection from the internal fan join both together, wire fits through top vent, so now cools great and turns off in standby
            • nice guy
              • Jan 2012
              • 11
              get one of these
              Looks like very brilliant mate....Do you have the fan on the box? This on you linked from ebay, Is this quit???? which on did you buy?
              I have seen fans with 3 pin molex connector...is 3 pin compatible with dreambox...I think it should be because i am cutting at the and and the volt are same 12v.
              • nice guy
                • Jan 2012
                • 11
                Thanks a lot
                • nice guy
                  • Jan 2012
                  • 11
                  I have found other 80 and 120mm fans from nexus and fractal design but problem are that fans has 3 cables, black,red and yellow...and the internal fan have 2 cable only black and red....what should i do...is it possible to live the yellow cable....Will it work without wire the yellow cable.....
                  • foxlife
                    • Jul 2010
                    • 5
                    Use black and red. Yellow is sensing RPM. Test before closing.
                    • nice guy
                      • Jan 2012
                      • 11
                      Thanks mate...A friend of my said same as you and i bought a nexus 120 mm fan and its deadly quit....
                      Thanks to all people who helped me......
