freezes during playback/rewinding/FF
  • vkilbi01
    • Apr 2012
    • 13
    Hi, I just wonder if anyone has experienced the same problem I have on my hd800? When I playback recorded video, during rewind or FF, - the dreambox can freeze for quite long time (several minutes) or even doesn't wake up so I have to reboot it from power. Have tried several images, connected hard drive internally, as USB or E-SATA (external SATA) and it didn't make any difference. Have used different formats (ext2, ext3, fat32) - no difference. I have Seagate 500gb drive.
    Is there a cache that I can increase in size? Any other ideas?
    Thank you
  • Rodbouy
    • Jul 2010
    • 1320
    what image are you using ?
    • vkilbi01
      • Apr 2012
      • 13
      Have used at least 20 different images, currently have flashed with Black Hole experimental 2011-01-15 - no difference.
      • Rodbouy
        • Jul 2010
        • 1320
        If is sim 2.01 then flash the bootloader 84a then flash pli 2.1 beta.
        Best image so far I have found for recording.
        • vkilbi01
          • Apr 2012
          • 13
          Sorry for the late reply. I have tested mount on my home PC hard drive (NTFS) and it records, plays back and rewinds fine. The problem is only if the record is to the Dreambox internal HDD.
          Could you please give me links to 84a and pli 2.1 beta you already have tested? Cheers.
          • Rodbouy
            • Jul 2010
            • 1320
             http://www.dreamoem.com/showthread.php?181-New-secondstage-dm800hd-sim2
             http://www.dreamoem.com/showthread.php?249-OpenPLi-2.1-beta-dm800
            Download ssl then put box in stop mode, flash SSL like a image, once down turn off box and put back in stop mode.
            Now flash the pli img.
            • IAmATeaf
              • 591
              The image that Rodbouy has linked to is ssl84b so make sure you grab the 2nd loader in the first link, although as the image contains ssl84b and if you're up to ssl84a then I think that the image will install without any probs but am not sure.
              • vkilbi01
                • Apr 2012
                • 13
                Thanks for the detailed explanations but is this site alive? I am not able open link and site http://www.dreamoem.com/
                • Rodbouy
                  • Jul 2010
                  • 1320
                  As long as you have ssl84a installed the 84b will install from the image.
                  but you do need 84a loaded 1st.
                  • Rodbouy
                    • Jul 2010
                    • 1320
                    ssl84a
                    Img here
                    • vkilbi01
                      • Apr 2012
                      • 13
                      Downloaded successfully - thank you, just a question: first file I have downloaded (ssl84a) has compressed readme.txt, .ipk, .bin and .nfi files. In my understanding when flash I have to navigate to .nfi file. Should I run/install .ipk file after I finished flash?
                      thanks again
                      • Rodbouy
                        • Jul 2010
                        • 1320
                        thanks again
                        just the nfi file, then turn off and put back in stop mode. thjen flash image
