no ca found
  • mangy
    • Mar 2012
    • 4
    no ca found
    hello,i have read post on this problem,i have dreambox 800 hd se with error no ca found,i want to reflash it what is the best way please,every one are saying different ways i only want one simple way please,thanks mangy
  • mast
    • Nov 2010
    • 1027
    Have a read of this thread and also you can search and download optiflasher which is easier to use.
    Regards
    • lincsat
      • 1228
      If you have the little button on the back, you can use that to boot into the standard web flash mode.
      • mangy
        • Mar 2012
        • 4
        hello,i do not have button at the back,and i have just notice the service socket you put the mini conection in is broken,can i do flash without this.thanks any help on this
        • mast
          • Nov 2010
          • 1027
          If your mini connection is broken then I think you are stumped unless someone can come up with something.
          Regards
          • mangy
            • Mar 2012
            • 4
            hi can it be done with ethernet only,thanks
            • potrobber
              • Mar 2010
              • 493
              dm800hd use optiflasher and com port to com port connection with null modem cable
              this way has fixed all the boxs people have brought to me
              • mangy
                • Mar 2012
                • 4
                hello,can you explain how to use this with com port to com port please thanks
                • mast
                  • Nov 2010
                  • 1027
                  The com port mentioned is the mini port you are talking about I thin which is why you are stumped because you cant get rid of the error via ethernet.
                  Have you opened the box up and had a look maybe you can solder back on.
                  Regards
