White Sky Card for FTV Channels
  • Chris2k
    • Jun 2012
    Hi,
    I recently bought a white Sky Card.
    I don't want to watch Premium Channels, only the FTV Channels like E4. (I'm living outside the UK..)
    I've inserted it into the Card Slots in my DM800HDse, but the card doesn't seem to work...
    I'd really love to watch british TV, so please help me :-)
    I'm using CCcam:
    My Config only contains the following line:
    SMARTCARD CLOCK FREQUENCY: /dev/sci0 3580000
    My Entitlements:
    card reader /dev/sci0
    handled 19(18) ecms and 0(0) emms
    Nds card 2c65a13
    Entitlement info
    card reader /dev/sci1
    Starting CCcam:
    root@dm800se:/etc# /usr/bin/CCcam_2.3.0 -d
    21:50:41.714 CCcam: ======================================================================
    21:50:41.715 CCcam: starting CCcam 2.3.0 compiled on Dec 15 2011@23:38:08
    21:50:41.715 CCcam: ======================================================================
    21:50:41.716 CCcam: online using nodeId 4b7e6693108e281b
    21:50:41.719 CCcam: dvb api3 detected
    21:50:41.720 CCcam: DM8000 detected
    21:50:41.720 CCcam: create 8 cam device(s)
    21:50:42.088 CCcam: /dev/sci0 configured clock frequency: 6000000 Hz
    21:50:42.992 CCcam: nds card found(new type)
    21:50:45.996 CCcam: card init fail
    21:50:46.220 CCcam: added 178 keys from /var/keys/SoftCam.Key
    21:50:46.220 CCcam: readKeyfile: cannot open /var/keys/AutoRoll.Key or not found
    21:50:46.221 CCcam: static cw not found or bad
    21:50:46.221 CCcam: parsed 0 entries from /var/etc/CCcam.prio
    21:50:46.274 CCcam: added 1274 provider names from /var/etc/CCcam.providers
    21:50:46.275 CCcam: added 4 channel names from /var/etc/CCcam.channelinfo
    21:50:46.276 CCcam: server started on port 12000
    21:50:46.353 CCcam: /dev/sci0 configured clock frequency: 6000000 Hz
    21:50:47.257 CCcam: nds card found(new type)
    21:50:47.279 CCcam: found nds caid: 0x963 ecmpid: 0x50a id: 0x0
    21:50:47.279 CCcam: found nds caid: 0x961 ecmpid: 0x50a id: 0x0
    21:50:47.279 CCcam: found nds caid: 0x960 ecmpid: 0x50a id: 0x0
    21:50:47.280 CCcam: cam[0] set PMT for sid=128f
    21:50:47.280 CCcam: start EMM
    21:50:47.334 CCcam: nds: using boxkey 00000000
    21:50:47.364 CCcam: cam[0] ecm odd nok caid:0x963 id:0x0 pid:0x50a SKY UK (28E)
    21:50:47.405 CCcam: EMM demux 1 set
    21:50:47.405 CCcam: EMM: not interested in 0960:000000
    21:50:47.405 CCcam: EMM: not interested in 0961:000000
    21:50:47.405 CCcam: EMM: not interested in 0963:000000
    21:50:47.458 CCcam: cam[0] ecm odd nok caid:0x961 id:0x0 pid:0x50a SKY UK (28E)
    21:50:47.486 CCcam: card added to broker with caid 963
    21:50:47.487 CCcam: start EMM
    21:50:47.552 CCcam: cam[0] ecm odd nok caid:0x960 id:0x0 pid:0x50a SKY UK (28E)
    21:50:47.605 CCcam: EMM demux 1 set
    21:50:47.605 CCcam: EMM: not interested in 0960:000000
    21:50:47.605 CCcam: EMM: not interested in 0961:000000
    21:50:47.605 CCcam: EMM: start filter on nds emmpid: 0xc0 caid: 0x963 id: 0x0
    21:50:47.646 CCcam: local ecm -> card /dev/sci0 0x963(0x000) sid 0x128f
    21:50:47.732 CCcam: local ecm <- card /dev/sci0 ok
    21:50:47.734 CCcam: cam[0] ecm odd ok caid:0x963 id:0x0 pid:0x50a SKY UK (28E)
  • freck
    • 1076
    Point your dish to 28.2 E and do a scan or enter SGT Flip Flops channel list....no need for a card.
    DM800se is fta receiver till you mod it
    Freck
    • Chris2k
      • Jun 2012
      Hi,
      Thanks for your answer!
      Hmm.. My dish is already pointing at 28.2?E.
      I'm getting the FTA Channels, like CBS Channels (Action, Reality, ...) Horror Channel, and a few others.
      I can also watch Pick TV without card (though i thought it's encrypted? But PickTV also works on my Samsung with integrated tuner.)
      But Channel 5 / E4 / ITV is not working.
      So i bought a Sky White Card at eb*y.
      When i put in my card, it seems like i don't get any Updates. In the WebIF i see lots of ECM NOK.
      I've also tryed setting up OSCAM with CCCam, but there's the same Problem.
      As i've read i don't really need a Boxkey, since i don't want to view Premium Channels (as i don't have a subscription either).
      As mentioned above, i'm living outside the UK and can't receive Astra 2D, only Astra 1N.
      • davvo
        • Apr 2009
        • 666
        are all fta on Astra 1N
        no card needed
        if you can receive Astra 1N then you should get most or all of the channels
        all Astra 1N fta channels
        if you cant get any of the above channels
        then get a bigger dish
        • gji25
          • Feb 2010
          • 353
          depends where you are.. as said above, could be you need a bigger dish. a 110cm dish should suffice if your in central europe
          dm500hd -dm500hd v2-vu+duo- triax 1.1m - inverto lnb - technomate 2300 motor- linksys ddwrt router
