What causes Dreambox to overheat?
  • oregon2000
    • Apr 2011
    • 13
    I am considering buying either a DM800SE or a DM7025HD but the 7025HD has no fan.
    I wanted to ask if its having an internal HDD in the box that causes some dreamboxes to overheat? Or do they get hot anyway?
  • the rock
    • 217
    they do get its like any piece of electrical sat box i f your going to spend that kind of money buy vu duo original same system enigma 2
    • DOUGALMCD
      • May 2011
      • 3229
      As with any electrical equipment you are always advise to make sure it isn't enclosed and well vented. I suppose with hdd in there is less space in box so air doesn't vent as well but you can always add fan. Or buy a box with one.
      • the rock
        • 217
        you could always buy laptop cooling fan i have one on my original dreambox dm 800 still a little hot but hey thats the way things are
        • oregon2000
          • Apr 2011
          • 13
          Is your fan outside the box or in? Does it switch off in standby?
          • firestorm
            • 1550
            It should be ok as long as you keep of the Private Spice channel
            • alom5
              • 1648
              I got the 800hd and 800se the se does not get hot at all as it has a massive fan in it.
              The hd does get hot after a while...so i have a dan under it and they have been working great for well over a year now....
              • oregon2000
                • Apr 2011
                • 13
                Thanks alom5
                Where did you get your fan from? Does it power off in standby?
                • smoggie
                  • 863
                  you can get a cooler from the likes of poundland and can be wired into the AV socket so they power off in standby
                  • oregon2000
                    • Apr 2011
                    • 13
                    I wouldnt have a clue how to wire it. Is it difficult?
                    • alom5
                      • 1648
                      got mine from fleabay and mine is always on....it's only the tiny ones...my box is in side a cabinet tho....
                      • smoggie
                        • 863
                        have a look here http://www.digital-kaos.co.uk/forums...al-fan-186851/
