flashing
  • bobon5106
    • Aug 2008
    • 75
    flashing
    How to Flash a new firmware for DM800 HD
    Flashing a new firmware (image) by Browser
    What you need to flash
    You need the image file you want to flash. Image files have the extension *.nfi. You can't flash other
    images like *.img files. Don't try it - it won't work.
    You need either a DHCP server, a configured bootloader or a serial cable and a terminal program
    like HyperTerm.
    You need a browser, and a network cable. If you connect the Dreambox directly to the PC,
    you need a cross cable, if you connect trough a switch/hub/router you need a normal
    (non-cross) cable.
    To flash a new image, you can use the second stage loader. It must be present and not broken.
    The following steps assume you have a DHCP server. If you don't have one, you have to setup
    an IP address in the bootloader's serial setup.
    - Power down the Dreambox, either using "shutdown" and by removing the power connector.
    Standby is not enough!
    - (1.) Press and hold the power button. Replug the power connector into the Dreambox.
    - (3.) A text "*** STOP ***" should appear. Now you can release the button.
    The bootloader entered the "waiting" mode.
    - (4.) Above the "*** STOP ***" text, there should appear an IP-address
    (four decimal values with a dot in between). If there appears the string "dhcp" instead,
    the box still searches for a DHCP server. Wait a bit. If it doesn't change, something doesn't
    work with the DHCP server. Check wether network cable is plugged in etc. If it just doesn't
    work, set an IP using the serial terminal)
    - Now, open a browser on your PC.
    (1.) enter in the address line "http://ip/" (where ip must be replaced with the value in the LCD).
    - (2.) on the bottom of the page, there's a link called "firmware upgrade". Click it.
    On the next page, you can select the flash image you want to flash. be sure that it has the ".nfi" extension.
    You can't flash other images (like .img)!
    - Click on "FLASH!" and wait. It might take some time to upload and flash the image.
    - Switch the box off again, and on again. The new image should be flashed and working
    hope this helps
    bobon5106
  • ces
    • Mar 2009
    • 104
    Top post bobon5106 .... but why change the flash mem contents... when all need to do is install additional memory or adding a hardrive to install new firmware.... remember the 800 is a new product & alot of people will buy from new with warranty so if new firmware is installed to its flash mem & the stb go`s tits up the warranty is void.
    ces
    • bobon5106
      • Aug 2008
      • 75
      ces
      this box is new to me i normally use my 7020 i am no expert and just trying to post the problems i had in setting it up i have read and searched for answers hopefully like you have posted more help for others and myself will come of it these boxes are not cheap and would advise anyone getting one to read and search then ask the ???? before doing anything to the box
      my h/d as not come yet so just used wot i had available at the time
      bobon5106
