mgcamd and openpli
This topic is closed.
  • Grizz
    • 1598
    mgcamd and openpli
    wondering can anybody help me.
    installed openpli 2.1 on my dm800hdse. then installed mgcamd then put in a mg_cfg file in the /usr/keys folder, (one that a "friend" had given me if the original didnt work)
    then installed ActiveCode plugin and punched in my code and it activated
    however no channels are clearing.
    had all this working up to yesterday on Newnigma2, just cant figure out where im going wrong with OpenPli
    ive tried different versions of mgcamd from tspanel, different versions of the mg_cfg file. reinstalled image, just cant get it going.
    Please help save my last few hairs
  • IAmATeaf
    • 591
    Do you have a file called newcamd.list in /usr/keys, if you have edit it and check its content.
    • Grizz
      • 1598
      thanks for reply iamateaf.
      it wasnt there when i downloaded mgcamd from openpli but was there after i did from tspanel. can you tell me what i have to edit? all i have is the activecode number and im at a loss as to how they all tie in together
      • gji25
        • Feb 2010
        • 353
        1 First Make sure you have installed Mgcamd 1.35a ,1.35 or 1.31
        2 Using Dcc ftp to your box
        3 browse to "/usr/keys" folder DM800HD,DM500HD & VU+Duo and Solo or /var/keys DM500s
        open " newcamd.list" file and add the below CWS=line save and exit file: example below
        CWS = hostname-url port-number user pass 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan newcs
        5 Right click on " newcamd.list" file after replacing and set attributes to 755
        6 Select Mgcamd EMU with blue button and restart
        dm500hd -dm500hd v2-vu+duo- triax 1.1m - inverto lnb - technomate 2300 motor- linksys ddwrt router
        • Grizz
          • 1598
          hi gji25. i dont have hostname url port-number user pass. .all i have is an ActiveCode number. i open the Activecode plugin and punch in a number and everything works.
          when i installed it in newnigma2 i didnt have to do anything to the newcamd.list, just install mgcamd, then config file then , avatarcam plugin.
          just not sure how they tie in so i can do it on openpli.
          • gji25
            • Feb 2010
            • 353
            im using open pli image on my dm500hd and the mgcam works fine. where exactly did you get the code? is it a active c/s ?
            • Grizz
              • 1598
              yes its just a 13 digit number that i enter into the ActiveCode plugin. tells me that its activated and i have xx days left. yet, nothing happening on screen.
              • satsmo
                • 6397
                Please take this to pms or offline, thanks.
