Need help scaning for Sky scrambled channels
  • seany123
    • Jun 2012
    • 12
    #16
    Can anyone suggest where i can buy Original Boxes? and Original parts?
    Anyone know if this website is legit/sells original box's / original parts?
    http://www.satstore.co.uk
    Originally posted by The fat man
    have you installed cccam or mgcam and selected one of them ?
    also you know the scrambled channels wont unscramble without the correct config file installed don't you?
    yes its installed and enabled.
    Originally posted by cactikid
    check the names of channels on kingofsat to see if they match as if you get different names either dish has moved or selected sat is wrong
    Astra 1N / Astra 2A / Astra 2B / Astra 2D / Eutelsat 28A (28.2E) - All transmissions - frequencies - KingOfSat
    Eutelsat 25A (25.5E) - All transmissions - frequencies - KingOfSat
    do you have another sat box or sky box and is working ok?
    http://www.lyngsat.com/Eutelsat-28A.html
    Sorry im a little confused as to how to use this list? i only had a Sky+ box and the old sky box both worked with the same dish/lnb.
    Originally posted by bowden2010
    lnb cud b broke
    i doubt that it possible because the channels worked with my sky+ box so it should be working with this box?
    • Elric
      V.I.P. soft lad
      • 853
      #17
      do you get any fta programms like bbc itv channel4 etc
      • seany123
        • Jun 2012
        • 12
        #18
        Yes all the channels you listed work.
        • smoggie
          • 863
          #19
          have you installed cccam and activated it? Do you have a working sea lion?
          • seany123
            • Jun 2012
            • 12
            #20
            Yes i have CCcam 2.2.1 and i activate it, im sorry i dont know what sea lion is i will search into that and let you know.
            • andy91
              • Aug 2010
              • 3583
              #21
              Google card sharing and that will tell you basically what you want to know but keep this talk to pm as its against the forum rules mate.
              Andy.
              • seany123
                • Jun 2012
                • 12
                #22
                I dont currently have a c-line but surely i dont need 1 to just test and make sure im can receive these non-fta channels....
                • andy91
                  • Aug 2010
                  • 3583
                  #23
                  You dont mate but drop the sea lion talk.
                  Once the CCcam has been installed if you go to a premium channel it will be scrambled if you see a high snr then you know it will work with a sub,
                  Andy.
                  • seany123
                    • Jun 2012
                    • 12
                    #24
                    Andy.
                    Yes thats what i thought but instead im getting "tune failed" errors and 0% snr
                    • cactikid
                      • 12017
                      #25
                      can you try and scan your box in a m8s house to see if it picks up those extra channels,you should get over 900 channels on 28.2,if it does pick them up possible dish movement might have happened,how long was it last used on previous box and latest box day or a year?
                      • seany123
                        • Jun 2012
                        • 12
                        #26
                        Well i will try and use the box round a friends house and see what happens, but the dish was working perfectly fine with my sky+ box around 2 weeks ago (before my box broke)
                        • andy91
                          • Aug 2010
                          • 3583
                          #27
                          Have you activated CCcam and moved from Common Interface?
                          Take it you have a recent set of bouquets on the box?
                          Andy,
                          • seany123
                            • Jun 2012
                            • 12
                            #28
                            Andy,
                            yes i have activated CCcam and i get a CCcam started message, i dont know what you meanby moved from common interface.
                            Yes i have downloaded and installed the latest Bouquets from SGTFlipFlop SKYUK Bouquets thread.
                            • micflair
                              • 275
                              #29
                              Sorry if its already been mentioned, but have you tried another power supply for the box? A dodgy psu can sometimes cause these kinds of errors.
                              • southpaw
                                • 2233
                                #30
                                you may need to list what steps you have taken so far
                                did you do a scan at any point and select only fta channels ?
                                is your tuner configured properly
                                simple
                                single
                                28.2
                                i would check connection of coax to dreambox
                                check tuner configuration is as above
                                upload sgt flipflops settings again
                                reboot and it should be good to go once you enter your sea lion
