Dm800 problem
  • homer41
    • 207
    Dm800 problem
    Hi guys i have got a dm800hd sim201 on bootloader 76c on the pheonix dreamelite 1.33 image. However on this particular box it keeps making it crash green screen then it gets stuck on booting, a reflash cure the problem for 3 days or so. Any ideas what the solution could. In addition the box is connected to the tv using scart, this is the only one i have connected using a scart and its causing me issues
    Cheers guys
  • plasterer
    • 1631
    Poss over heating mate ,try a fan under it,
    Though mine runs 24/ 7
    With no fan at all ,even disconnected the one inside
    Never had a prob yet
    Why you running an HD box on a scart ???????????????
    Try above add a HD cable and post results
    Ime running that image along with most 800 users............Paul
    PAUL
    • homer41
      • 207
      Yh i thought over heating also but i got a few boxes as u say with some fans disconnected and they are running fine. Reason its using scart is because the guy hasnt got a hd tv, i was thinkn is the scart drawing excessive power on hd channels possibly?
      • southpaw
        • 2233
        when the green-screen happens it will create a crashlog somewhere in your media folders , either usb or hdd , should give some info as to whats causing the crash
        • homer41
          • 207
          Hi cheers for ur reply unfortunately it doesnt have a hddor usb attatched
          • southpaw
            • 2233
            Not sure were they would save too in the absense of a media/storage folder, probably there somewhere , certainly worth having a poke around with an ftp programme
            • homer41
              • 207
              Ok mate will have a check but the box doesnt boot back up once it crashes so i would unable to ftp to it. I put another image on, will so how i go from here. I have a feeling its crashing because its using scart.
              • southpaw
                • 2233
                the crash log will still be there when you restart mate , think it can store several logs (each will have a date in the crashlog title)
                • Rough Daimond
                  • Apr 2011
                  • 63
                  most crashes are due to no space on the flash after you install ts panel addons and bouqets..check how much room you have left.
                  • homer41
                    • 207
                    i have 12mb left, all i have on the box is the image, bouquet and cccam. dont even have epg haha
                    • Rough Daimond
                      • Apr 2011
                      • 63
                      sounds like you may have a faulty sim?..i think you can buy them
                      • southpaw
                        • 2233
                        how did you come to that conclusion mate ?
                        • homer41
                          • 207
                          yh i didnt think the sim held 64mb of flash?
                          i got the fella to use the box on dvi cable been ok for a few days fingers crossed
