Ts panel
  • homer41
    • 207
    Ts panel
    Hi guys were on the a dm800 can i install the tspanel? I understand the original way of installing it using the ftp method and installing the ipk file to the box flash. Is there any other place the box where i can install it to e.g usb or hdd? Cheers
  • blueflash234
    • Mar 2009
    • 904
    download filezilla or dcc e2 and ftp the ts panel to the temp folder depending what image it is press long blue button then software mangement then manual install reboot then you should see it in the plugins
    • southpaw
      • 2233
      if your asking if you can use external media to run plugins then the answer is no , they need to be installed to the flash memory which obviously has limitations
      only option for using hdd/usb is a dual boot type scenario like "barry allen or meoboot" which allows you to trial and run differant images from external media,
      • homer41
        • 207
        ok guys cheers for the replies, gives me a better insite into knowing where things are going
        • xZEDx
          • 69
          hang on i thought once flash expander was installed the plugins would be by default installed on usb memory?
          or have i got the wrong end of the stick
