dm800hd pvr clone
  • crazyturk20
    • Jul 2012
    • 6
    dm800hd pvr clone
    hello all i got an problem whit my dm800hd pvr i did installed orther image and my dm just giveing an error whit NO CA FOUND so i need rs232 cable i got that cable.
    but what for imaje i need i think my bootlooader is shutted down too i need an image whit bootloader and image.
    Run this programme and it will repair the error no ca found then flash with the correct image for your bootloader Digital Kaos - Downloads - Dreambox NO CA FOUND Repair Tool SIM2 EDition V2.5
    • crazyturk20
      • Jul 2012
      • 6
      thanx for ur help firstly,
      do i need rs232 and nulll modem cable for it?
      and what is my sim model
        Yes connect with Rs232 and an ethernet cable, run programme it will give you a choice of bootloaders. Try a lower one if your not sure what BL you have, then flash an image with that bootloader on.
        Edit: I don't think you need an ethernet to run this but you will need it to flash your new image if your not going to use a web browser.
        • crazyturk20
          • Jul 2012
          • 6
          is there a bootloader whit image included because i am scarred to make him broke again.. and which one is good for dm800hd PVR
            Just use a null modem from pc to box. When it has repaired the error, you can flash a new image from the web browser.
            • crazyturk20
              • Jul 2012
              • 6
              no i dont got rs232 on my pc so usb>rs232>nill modem.
                You can try it. Some people have success using a usb one but i never have. You've got nothing to lose by trying it
