Internal hard drive in a dm800hd pvr clone
  • phat1
    • 114
    Im have install a 2.5 sata internal hard drive in a dm800hd pvr clone.
    1. How do i format it and mount it.
    2. Am im suppose to install any pluggins or addons.
    Any help would be great and if i left something out that i need to do/no please let me no.
  • dreamuser12
    • Aug 2012
    • 59
    what image are you using, in my image you goto MENU->SETUP->SYSTEMS-> Storeage device, in blackhole i thinks its MENU->SETUP->SYSTEMS->Harddrive
    dreamuser
    • phat1
      • 114
      [QUOTE=dreamuser12;1719757]what image are you using, in my image you goto MENU->SETUP->SYSTEMS-> Storeage device, in blackhole i thinks its MENU->SETUP->SYSTEMS->Harddrive
      dreamu
      Dream Elite Black Hole V 1.0
      DM800HD_SIM201-SSL84_dreamelite-Blackhole:
      TSPanel 6.3
      So i read your post and that worked it is now initialing hard drive. Thank you.
      would u no how i set up an epg thanks
      • dreamuser12
        • Aug 2012
        • 59
        its easy to setup epg, check if crossepg is installed and if not download it from TS panel, to check if its installed goto MENU->SETUP and look and see if its in their, if not dwnload and reboot, then goto MENU->SETUP Crossepg, then Configure then change scheduled dwnload to once aday, click back and goto open tv and select sly uk 28.2, then back if u wanna update ur epg manualy goto ur panel, probley green button and click crossepg dwloader and wen it done u need to restart enigma2, now your epg guide should be updated
        dreamuser
        • phat1
          • 114
          Done thanks a mil. I can record ihave tryed and tested it. Im now looking to see if there is a easer way to record is ther and addon r plugin that make easer to record.
          • dreamuser12
            • Aug 2012
            • 59
            it is easy to record, if u want to record the program ur watching, just press the red button or the button with the red dot, it depends on ur remote, if u want to set recordings for later or nxt day or any time in the next 7days then,theirs 2 ways, u can use multi epg and just press green twice on wat u wanna rec, or easyer way, if u no what channel the program is on, press Bouquet then high that channel, then look along botton of screen and see if u have options like, 1=search 2=single 3=multi epg, press 2 and it will show u wats on for the nxt lot of days, if theirs no numbers along bottom, then press info button on the channel u wanna rec and select tv program to rec.. now would u like me to show you how to pleasure a woman lmao
            dreamuser
