Recording/motor prob 800HD
  • mickz
    • 48
    hI ALL,
    Just manged to get my DM800 up and running with a lot off help from you guys on this forum.
    (Thanks for all your help).
    But when i record a program via timer to internal h/disk should the motor move itself to the correct location E.g If left on hotbird and recoreding s timed for a channel on astra will the machine move the motor automatically like most recivers do.As off yet i have found no solution in setting etc.
    Using nab black hole image.
    Thnaks in advance.
    Mick
  • cauliflower69
    • 261
    instead of setting it to record set it to zap at that time and see if it moves the motor then
    • mickz
      • 48
      Thank you for your response, I will test the Zap tonight, Does the box have to be on Full Power on or will standy by work ?
      Cheers
      • cauliflower69
        • 261
        standby should work
        • NewBirth2010
          • 56
          I have the same problem. If it is set to Standby then recording using the timer does not move the motor.....
          Any Ideas?
          • NewBirth2010
            • 56
            Any ideas? I think it is a bug...???
            • NewBirth2010
              • 56
              Ok. I found the solution guys...
              Just upgraded the firmare to Dream Elite BH 1.3.3 OE1.6 DM800 Multiboot
              It works Rock Solid now !!!
              Even from Standby.....
