DM800 Tune Problems
  • madaboutlotus
    • Feb 2012
    • 27
    DM800 Tune Problems
    Hi Guys
    I wonder if you can suggest what to do next.
    I have been having a lot of trouble with channels not tuning in and an error message 'Tune Failed' popping up. After several re-flashes with new images, a replacement tuner, checking the connections, alignment and signal strength is fine accoring to my other boxes, the box worked fine with all channels viewable for the space of 2-3 hours then it packed up again with for instance Sly Sp1 & 4 OK, but Sp2 &3 not. I have a notebook cooler under the box which keeps it cool.
    I can't think what to do next unless the box is goosed and whatever I do will not bring it back to life.
    Any suggestions would be appreciated.
  • marcus1975
    • Jul 2011
    • 248
    Buy a original box and not a clone
    You can have a lot of issues with clones
    [I]Dreambox 800HDse,SUPERIOR DARK MOTOR METAL GEAR DiSEqC 1.2 ,Gibertini 1m Satellite Dish,FaVal TWIN LNB 0.1dB Universal Edition V2 HD SD TV
    • yamar1
      • 970
      helpfull reply that mind.
      im having issues also with my tuner the box is saying tuner empty, its a clone and was fine for 2 years till i unplugged the box for a few days.
      Faster than Faster
      • madaboutlotus
        • Feb 2012
        • 27
        Are you considering a change and if so what would you go for?
        • marcus1975
          • Jul 2011
          • 248
          I have had an origonal l for 3 year and never had a problem with the tuner. Yes change i would go for a origonal 800 HD se very good. You always get what you pay for
          • yamar1
            • 970
            tbh i would go for another 800 clone, none se, im going to try another tuner first.
            Faster than Faster
            • madaboutlotus
              • Feb 2012
              • 27
              I did try another tuner without any success, still getting 'tune failed'. New Transponder next.
              • uu161
                • May 2012
                • 372
                tuner fail higher chances will be the signal side
                seem you had already try another tuner card
                if you like the post use the Like button located bottom right corner of each post
                if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
