can not get CCcam.cfg file working! Please Help!
  • stevo88
    • Oct 2012
    • 70
    Box - Ferrari Vu Duo
    Image - Vix 2.4.96
    CCcam 2.2
    ok so basically i had my box working for around a week but had some problems with the hdd causing the tuner to fail when a recording started, so anyhow i have re flashed box and am at the point of ftp CCcam.cfg file to /etc but its not working!
    I got a cfg file template which i have added my line to in notepad and its transferring over as a cfg file but only my fta channels are showing...
    keep getting the error -
    SoftcamCheck
    Error:[Failure instance: Traceback: ,type
    'exceptions.IOError'>:[Errno 2] No such file or directory:
    '/etc/CCcam.cfg'
    theres loads more but hopefully someone can diagnose off that.
    in filezilla everything transfers over ok but doesnt work, the file is still being transferred in notepad but is not showing as a .txt file it is showing as .cfg in properties.
    i think it must be somehow the way the file is formatted because i think last time the cfg file symbol was a blank page but now the symbol is notepad but tbh i just dont know.
    been at it for hours trying to remember what i did last time, tried everything i can think of!
    Please Help!!!
  • stevo88
    • Oct 2012
    • 70
    using N line btw
    • mdt
      • 3034
      Originally posted by stevo88
      using N line btw
      if your using a N then switch to mgcamd and see if it sorts it,regards mdt
      • davvo
        • Apr 2009
        • 666
        use dreambox control center
        with telnet
        start dcc
        telnet
        paste these in one at a time press enter after each paste
        touch /etc/CCcam.cfg
        chmod 644 /etc/CCcam.cfg
        or use putty if you want to do it remotely
        start putty input ip
        login as root
        input password
        paste lines in above
        • stevo88
          • Oct 2012
          • 70
          looking into mgcamd now boy if i wasnt confused before i sure am now :/
          • davvo
            • Apr 2009
            • 666
            why are you confused
            make the file properly with the 2 commands
            with dreambox control center
            then edit the file with dreambox control center
            or filezilla
