Dream Up
  • JT75
    • Feb 2012
    • 35
    Dream Up
    Hi All,
    can someone explain why this program takes over 1 hour to flash image
    UPversion 1334.
    also advice on which image i best for my dreambox 800HD
    SIm 201 Bootloader 84B I have used PLI Nemissis 2.3. what should i be running in my box for 30W & 28.2E???
    Many thanks in advance.
  • Rodbouy
    • Jul 2010
    • 1320
    Why are you not flashing over the browser in only a few min ?
    • JT75
      • Feb 2012
      • 35
      when i try flashing over the browser i have never been able to do it. always get a message saying image is old or something in that order
      • Rodbouy
        • Jul 2010
        • 1320
        You need to update bootloader then. If you have bootloader 82 and going to flash a ing with 84b then you need to update the boatloader to 84a. Then the ing with 84b will update from image.
        You flash the bootloader in same way. Put in stop mode..flash..turn box off and pit right back.in stop mode then flash image.
        • JT75
          • Feb 2012
          • 35
          I habe sim 201 and bootloder 84B.
          dream Up is almost finished now. will get it going tonight and will atempt to flash new image using broser.
          i was looking for blackhole image in the download section and could not find. can someone provide a link for the latest blackhole image as i hear good things about this image.
          Many thanks so far and many thanks in advance
          • blueflash234
            • Mar 2009
            • 904
            blackhole only do images for the vu's
            • JT75
              • Feb 2012
              • 35
              HI all
              Just installed nemisis from download section. all went ok installed TS pannel 6.6.
              the problem begins here went to download CCCam and i tried all CCCam versions and they give me the following error.
              failed to download HTTP response code said error.
              is there an alternative way to install CCCam or what can i do???
              Many thanks
              Regards
              J.T
              • Rodbouy
                • Jul 2010
                • 1320
                I believe they are modified for the 800. There is a few readily available.
                DreamOEM - The Front Page
                • Rodbouy
                  • Jul 2010
                  • 1320
                  Originally posted by JT75
                  HI all
                  Many thanks
                  Regards
                  J.T
                  Manually install cccam. Get tar.gz ftp to tmp then press green addons then manually install from options.
                  Then press blue and change cam from common to cccam then ok to start.
                  • JT75
                    • Feb 2012
                    • 35
                    sorry but i am new to this where can i find this tar.gz file ???
                    • Rodbouy
                      • Jul 2010
                      • 1320
                      Google the cccam forum you will find it on there mate.
