dm 800 wont boot first time
  • nush
    • Oct 2008
    • 178
    hi im after a bit of help with dreambox 800hd clone sim 2.10
    when i boot up from cold the box takes several attempts to get started. first couple of attempts only lan connection lights up. then the oled will flash on and then straight off again. then it will start and run really well. even if i switch power off for a few minutes it will restart fine, but left for an hour or more and im back to the same problem.
    anyone else had this problem and able to sort. thanks in advance
  • nush
    • Oct 2008
    • 178
    i should also add, i have removed tuner and cleaned contacts, same goes for sim card.
    im a bit stuck now
    • andy91
      • 3583
      Majority Will either say its a bad flash or change your power supply.
      Re flash it and see if that fixes it.
      Andy.
      • nush
        • Oct 2008
        • 178
        thans, i have reflashed but with a different image, just the same, ive also tried a different power supply with no luck. any other ideas
        • andy91
          • 3583
          Wouldnt think its the tuner but you could reboot without the tuner if its the same it might point to the motherboard.
          I would try an image like Pli thats pretty simple and hasnt alot going on it.
          Some of the other images arent that stable,
          Andy.
          • nush
            • Oct 2008
            • 178
            ive removed the tuner and i have the same boot problem, i will try pli image on monday when i have more time.
            • andy91
              • 3583
              Another option is to try different images with older bootloaders.
              Hopefully one might suit your troublesome box,
              Dont suppose you have sata hhd with it or loads of other plugins?
              Keep it as simple as possible,
              Andy.
