which cam runs lighter ?
  • mikk
    • 289
    Can a Cline only be read by cccam? I believe an Nline can be read by Mgcamd and cccam, is there any difference with regards to how they tax your internet connection? I had the option of a Nline but the former cam wouldnt install. I'm getting freeze due to my router dissconnecting.
  • TheCoder
    • Jun 2011
    • 693
    In terms of data traffic, the difference between the cams is negligable. All of them use relatively miniscule amounts of data bandwidth.
    Router disconnection is unlikely to be due to bandwidth, but more likely to be due to the far end server not responding or dropping the line.
    • mikk
      • 289
      It seems to be more of an issue with the box rather than web browsing on the pc, might it help to change changing the router port?
      • TheCoder
        • Jun 2011
        • 693
        Web browsing capability on your PC isn't really an indication of how reliable a carsderver is. If the path between the box and the server is slow or lossy, or the server itself is unreliable (ie not set up properly or oversold and overloaded) then you could get frequent disconnects.
        If your internet is otherwise ok then i'd suggest you try another server
