LNB Out
  • fbs1000
    • Dec 2012
    • 5
    LNB Out
    Guys apoligies in advance if this is in the wrong section. I have also searched this forum for my answer before posting.
    At the moment I just brought a DM 800 HD box, on the back it has LNB in and LNB out. My previous setup was S*Y with two cables coming from the Dish and into 1 and 2 on the back of the S*Y box (Obviously I could then record and watch a different channel at the sametime) I also had a normal cable from the back of the S*Y box with RF2 out turned on with a magic eye to the upstairs TV (bedroom) is it possible to have the same setup on the Dreambox. At the start of this post I wrote LNB in and LNB out, Obviously 1 of my lines from the dish go into LNB in - what exactly is LNB out and what does it do? and can I have the same setup as before on one of these box's like I did with S*Y - Thanks in advance guys.
  • fcukbcfc
    • 23
    the LNB out is if you set it up with a disq 1.2 dish motor v box so all you have to do is press which channel or sat and the dish moves to it.can't set up like sly two yvs from one box via a magic eye or which ever way you did have it.
