plugins wont load
  • mikk
    • 289
    plugins wont load
    I,m trying to load cccam but despite working previously now nothing. DCC shows it installed but nothing shows in the plugin menu after the box is re-booted. Any ideas on what might be blocking plugins?
  • southpaw
    • 2233
    depending how you`re going about it and which image you use it may well not be in the plugins list,
    press blue button on remote and look for "softcam" menu in there mate
    • mikk
      • 289
      Its the Oozoon image = user scripts-install local ipk. I will show it installing, reboot and nothing there? I've tried different images but the same thing. I'm guessing its something I've done. Would the factory reset button revert it to new out the box state, including ssl updates or is that not advisable?
      • nush
        • Oct 2008
        • 178
        not advisable
        • nush
          • Oct 2008
          • 178
          i dont use oozoon, do you have tspanel
          • southpaw
            • 2233
            try this, (cut+pasted from elsewhere)
            first install cccam for ozoon
            1-click blue button
            2-user scripts
            3-execute user scripts from /usr/script
            4-cccam_2.2.1.sh
            5-auto start
            failing that, install tspanel and use the "download ozoon cams" section to download a cam, then the "softcam manager" to start it (don't forget your config file in "etc"), it also has several other handy utilities in it epg, mount manager etc etc
            • mikk
              • 289
              If I remember rightly TS panel is not compatible with my box and there appears to be no softcams on the Oozoon server. One thing I miss from the Nabilo images is a proper blue panel. I have been placing the cam in temp so I'll try the former. Opinion seems to divided on the big reset button, some having no problem and some nightmares.
              • 00360362878
                • Mar 2010
                • 488
                A factory reset is only going to wipe your settings try flashing with a pli image you can then install your cams from their server mate.
                • mikk
                  • 289
                  Working finally. I've been looking for the plugin to appear in the menu, where I could set default cam etc. not so, I wasnt doing step 4 & 5 though southpaw, thanks for that. Now to **** it up again with barry allen.
