BH 2.0 w/2.1.4 CCcam
  • Roddypiper
    • Feb 2013
    • 13
    Ftpd the above cam using flashfxp to my solo2 box, then seleted and installed it through the blue button. Connected to my box through flashfxp again and removed all info from the CCcam.cfg and inserted my .....
    I am a little but stumped after this as I then expect it to do the neccesary business, however, it does not. Also restrted the box and nothing new.
    Where am I going wrong? I feel so close, yet so far away. My eyes are stinging and I am walking around like a bear with a sore head. This hobby aint half frustrating
  • freck
    • 1076
    All the usual cams for BH images wont work on the new image...you'll have to get the trr plugin and install the cams direct from that.
    Do a bit more digging around and youll find it,I wasnt aware of this image working on DM??
    Freck
    • Roddypiper
      • Feb 2013
      • 13
      so once I have access to the trr plugin, would I have to delete the other CCcams before installing this?
      I am sure I read a post from Benny that these cams I have are suitable for all BH vers... Hmm, but then again I have read so much.
      • benny/9
        • 1964
        i have just loaded the Black Hole Vu+ Uno v.2.0.1 OE 2
        on my box and i used the blackhole cam pack that i used on the earlier bh 172 image, i loaded them via the tmp folder and installed them with the remote, i posted the cam pack on the forum some time ago. also you dont need to remove anything from the cccam cnf file just add at the bottom of the file.
        Please Read Carefully!
        • Roddypiper
          • Feb 2013
          • 13
          Hi Benny,
          I am using the said cam pack. As mentioned, I get them installed, edit the .cfg and ftp back over, but nothing
          I have now installed the trr plugin and then installed it through the remote, after that, I am at a loss. I did not uninstall the cam pack though as I have no idea what this trr plugin is doing?
          • benny/9
            • 1964
            Originally posted by Roddypiper
            Hi Benny,
            to uninstall you click green then yellow buttons
            and then you see the blackhole addons manager
            scroll down to addon uninstall panel>ok
            now you will see the cam of cams you have installed
            to uninstall click ok on them one a time and follow the uninstall
            info,
            • Roddypiper
              • Feb 2013
              • 13
              so are you recommending that I uninstall the cam pack that you posted in an earlier post then, and use the trr plugin?
              • benny/9
                • 1964
                all i can say is the cam pack for the earlier images
                loaded and is working now on my genuine vu uno
                i hav'nt tried the trr plugging, i would use which ever
                works for you mate. as i said earlier you dont need to
                clear the cccam cnf file. you can just scroll to the bottom
                of the file and add there, also i use the DCC to use for my vu
                  There appears to be a problem with some cams and the new Blackhole 2.0.1 image its to do with the libcrypt version.
                  @OP please try and refrain from mentioning anything about CS we are not allowed to discuss anything in too much detail.
                  Thank you
                  • Roddypiper
                    • Feb 2013
                    • 13
                    my apologies and I will take note
                    • Roddypiper
                      • Feb 2013
                      • 13
                      any chance someone can pm me and give me some support on this? It would be greatly appreciated. I am absolutely confused
