remove unwanted languages from Openpli
  • frank087234
    • Jul 2012
    • 61
    HOW to remove unwanted languages, flags from Openpli, SAFELY???
  • gji25
    • Feb 2010
    • 353
    if you know how to programme in linux you can recompile the image and ommit the languages and flag icons that you dont want.
    dm500hd -dm500hd v2-vu+duo- triax 1.1m - inverto lnb - technomate 2300 motor- linksys ddwrt router
    • portbhoy
      • 717
      Ftp into the box, browse to usr/share/enigma2/po for languages and usr/share/enigma2/skin_default/countries for flags. I'm pretty sure you can just delete them.
      • frank087234
        • Jul 2012
        • 61
        I ve done this , now it wont bootup at all!!!
        • portbhoy
          • 717
          Hmmm strange shouldn't have effected your boxes ability to boot, I will give it a try and report back.
          • portbhoy
            • 717
            Ok did that and my box booted up fine but if I go into the language menu I go into a boot loop so ignore everything I just said. Now I'm away to reflash my box!!!
            • frank087234
              • Jul 2012
              • 61
              thanks mate, i told ya. I don't know why it is not that simple.
              • gji25
                • Feb 2010
                • 353
                like i said, if you know how to programme using linux you can recompile the image
                • frank087234
                  • Jul 2012
                  • 61
                  there must an easier way!!!
                  • southpaw
                    • 2233
                    unashamedly cut+pasted from elsewhere
                    Here's how you can remove unused system languages from your openpli 2.1 system
                    Important - Before you begin:
                    * Backup your Language.pyo from /usr/lib/enigma2/python/Components to a safe location so you can restore in case sth goes wrong.
                    * the supplied language.py mod is based on Openpli 2.1, I have no idea whether it'd be compatible on other images or not. But if you have access to language.PY version, it should be the same.
                    * Download the file below, there are 2 folders inside; original and edited for English only.
                    If you only want English like I do, then upload the edited version to /usr/lib/enigma2/python/Components, restart enigma 2 and you're done!
                    But if you want to edit it for your preferred language, then;
                    1 - Upload Language.py from original folder (download) to /usr/lib/enigma2/python/Components, then
                    2 - Open it with a python-capable editor, on a mac i use "Sublime Text 2", and navigate to Language (class), see screenshot...
                    3 - Edit/Remove all "self.addLanguage" sub-entries of those unwanted languages, keep only the one(s) you need, see screenshot...
                    4 - Save your edits then Restart enigma2 to apply...you'll only be able to see and select the languages you left out, see screenshot...
                    - Now, let's clean it up for good;
                    - go to /usr/share/enigma2/po/ and remove the very same languages you edited out of Language.py (step3 above)...
                    - go to /usr/lib/locale and do the same...,
                    - then go to /usr/share/enigma2/countries/ and remove the flags for those very same countries.
                    Bonus:
                    If you want to gain even more space, and i don't blame you if you've got an old dm800 like me; you prolly know that inside almost each and every system Plugin and/or Extension, there is a locale folder which translates the Plugin and/or Extension menus to your current system language, so by removing the languages you don't need from there, you are basically doing the same thing...reclaiming space that is just sitting there!!!
                    I hope this helps, Enjoy!
                    Thx to everyone who helped out, couldn't have figured it out by myself!
                    Download Here:
                    Language PY code.zip
                    • southpaw
                      • 2233
                      also from elsewhere
                      tspanel- from tools 2 -language manager will be able to remove languages and to restore them
                      • frank087234
                        • Jul 2012
                        • 61
                        Originally posted by southpaw
                        also from elsewhere
                        I ll try first method. The tspanel method causes the box to stop booting Up needing reflash.
                        • gji25
                          • Feb 2010
                          • 353
                          have fun and post back how you get on
                          • frank087234
                            • Jul 2012
                            • 61
                            The first method worked perfect.!!!
