usals or diseqc help
  • total newby
    • Feb 2011
    • 183
    hi im having trouble setting up my motorised dish, im not sure how usals and diseqc works , i have a 800 hdse and on the reception setting the options i have are positioner,single,toneburstA/B,diseqcA/B, diseqcA/B/C/D i cant see anything about usuals , i dont know if i need a disqc switch or anything else, i dont know if i have to change the image to one with usals or something , the sat is set on thor 1w at the moment but cant get my head round getting the dish to turn ,plz help as the motorised thing is totaly new many thanks, if i need to change the image plz recomend one at the minute its dream elite help?
    here is the description of the motor im not sure it supports usals-
    A High quality 1m satellite dish complete with a New Horizons Diseqc 1.2 Motor, L-Arm wall mount & a FREE 0.1db single output LNB
    Dish Colour is Dark Anthracite
    The simplest way for installation & upgrade to a motorised system
    • Specially designed for Receives with DiSEqC 1.2
    • Everything is controlled via only 1 coax cable
    • High Efficency Designed
    • Compact Structure
    • Ultra Low Noise
    • Adjustable Hardware Limits
    • For dishes up to 1.2m
    • Goto X Function
    Ave a read of this m8 it will put you right.................
    • total newby
      • Feb 2011
      • 183
      http://www.digital-kaos.co.uk/forums...ed-dish-42881/
      cheers for that but its based on usals i dont think my motor does usals i could be wrong but no mention of it in the motor description only diseqc 1.2 whatever that is
        Your motor does both accoding to google m8......................
        • mdt
          • 3034
          your motor is usals compatible but its called diseqc 1.3/go-to-x instead as they havent got a licence from eutelsat/stab who invented usals. just follow the guides and advice i and others have given you and you will be fine. just take your time and double check all your settings and at each stage of the process,regards mdt
          • total newby
            • Feb 2011
            • 183
            cheers guys i got the motor and dish from ebay heres the link- 100cm 1m MOTORISED SATELLITE DISH KIT + GOLD 0.1db LNB | eBay
            if its anyore help
            • southpaw
              • 2233
              positioner for motorized mate, then enter long an lat
