motor turns very slow not enough power ?
  • total newby
    • Feb 2011
    • 183
    hi im having a problem with my motor i have managed to set the lat-lon up pretty good and my motor seems to struggle to move to different satelittes, its like it isnt getting enough power and sounds like its struggling all the time , even if i manualy press the bottons on the motor its a hit or a miss wether it moves or not , it seems to move a bit better if the dish is pointing straight in line with the motor then struggles as the angle changes when switching satelittes, iv noticed when it changes from one sat to another it gets stuck half way and the orange light comes on, i have disabled any limits , checked the cables, tryed a different reciever, changed the power supply, everything seems good, it says in the motor manual that the reciever output power should be more than 350ma or more, i cant see any option on my dm800hdse for turning the motor power up and its doing my head in any suggestions ?
    image is nemesis 2-6 for the hdse
    co-axe cable is brand new solid not shotgun , plugs are all good with no shorts checked 10 times over thanks
  • mdt
    • 3034
    try changing the power threshold and make sure its set to fast,regards mdt
    • total newby
      • Feb 2011
      • 183
      done that mdt somehow can ony set it to 100 max set to fast no difference
        Logical step is to eliminate all possibilities first try another power supply in your Clone 800se, Different motor, different receiver altogether preferably one that is an original and not a clone
        • total newby
          • Feb 2011
          • 183
          i have tred everything i can think of, i decided to pull the lot back down of the wall, i made a 1m patch lead and connected the motor and the reciever togeather inside the house and its still doing the exact same i have tryed a different reciever and power supply and still no joy exactly the same , its a plain duffer by the looks of it so im sending it back on monday
            You see the process of elimination has worked you now know its a duff motor and problem solved Good Work
