no ca found by 2nd stage loader (dreamup)
  • frank087234
    • Jul 2012
    • 61
    i tried to flash DM800 by dreamup patched) (I could not flash via web), and got this above message on dreamup screen, although the lcd of dm800 displayed ip number, how can this be fixed? or does it need to be fixed??
    It is sim2.10,clone
    when i used optiflasher i got this result:
    Connection Ok!
    Dreambox Found in Tv Mode
    dm800
    Detected!
    Smart Check: SIM201-SSL-84a Detected!
    Does this mean second stage is missing???
  • skydive80
    • 168
    It is sim2.10,clone
    Connection Ok!
    dm800
    Detected!
    What image did you come from and try to flash, why can you not flash from web, r u using firefox?
    • frank087234
      • Jul 2012
      • 61
      I use Blackhole 1.7.0,ssl *84A which was working perfect ( I made backup) til i decided to flash 1.7.4, then flashed ssl84but this kept crashing on some plugins
      so I tried to reflash my backup, but would not connect via web firefox, which i normally use. so hook up dreamup which threw this no ca found by 2nd stage.
      • 786RAF
        • Mar 2013
        NO CA found dm800hd se clone.
        Hi i just had problem with my d/box dm800hd se clone & i tried for 2 days going in to diffident threads. is your box still stuck at this stage (no ca found) if so & your d/box is clone than use dreaqmup V1.3.3.8 as i tried few others but none work.
          Dreambox NO CA FOUND Repair Tool SIM2 EDition V2.5 - Downloads - Digital Kaos
          Give this a try m8
          • frank087234
            • Jul 2012
            • 61
            yes, the no ca meassage appear on dreamup only, not on lcd screen, (which will show ip addy) , i thought this is strange.
