DM800HD SE sim2.10 card ,Rev D6 newest verison or 300 mbps wifi
  • hsbajwa316
    • Aug 2012
    • 23
    Hi All
    Can you advise which is the best option for the above two items and the key difference as the wifi is slightly more expensive
    I currently have vu+ but am looking to take the plunge as I have heard good things about it?
    Thanks in advance
  • southpaw
    • 2233
    only you know what you need mate, do you require it to be wireless, if so go for the inbuilt wifi, if you got your router near your box or you house is cat5/6 wired go for the d6, both are pretty much the same only one has inbuilt wifi, the other can still use wifi, via usb dongles if that's a requirement for a later date
    • hsbajwa316
      • Aug 2012
      • 23
      Thanks mate, wifi is probably best then, i assume can you use an external harddrive on these for recording?
        The D6 is just the revision of the motherboard meaning that on the rear on the 800se it now has a mini USB and small flash button which should be standard on all Sim2 800se's
        The extra's as stated normally mean wi-fi or 3 triple tuner.
