DM 800 booting problem
  • chriskross
    • 1178
    hi! i have a Dm 800 HD PVR original, the problem is dreambox is starting to boot, then it aborted and restarts again, again and again.........
    i already flashed new orig DM image but i have the same problem
    can someone help me ??
  • BM300
    • 74
    Try using a program like Optiflasher to see if any bad sectors need repair.
    • chriskross
      • 1178
      do i need the function REPAIR [NO CA FOUND] ?? is there a key required?
      • chic.
        • 1599
        no m8 just click repair bad sectors
        if i helped hit the thanks btn
        • chriskross
          • 1178
          i found this video
          it is the same fault as i have
          there was there problem a defect tuner, has anyone already the same fault?
          • chic.
            • 1599
            did it work b4 ? have you checked the tuner is in properly? have you tried leaving it off for 30secs b4 switching it back on some boxes wont boot straight away after flashing?
            ps i dont think the tuner should stop the box booting up
            • chriskross
              • 1178
              hi m8!
              i removed now the tuner, and box is booting till the end.
              • andy91
                • Aug 2010
                • 3583
                Think I would try and flash again but with null modem cable and change the power supply. Andy
                • chriskross
                  • 1178
                  i saw there was bad soldering on one elko, i connected it back, then i saw in the red ring small short circuitelko.jpg
                  • andy91
                    • Aug 2010
                    • 3583
                    You can buy a new tuner for less than 30 quid off Ebay is your problem sorted?
                    Andy
                    • chriskross
                      • 1178
                      yep i will buy it,
                      i checked powersupply it is 12,23 V is this ok?
                      • andy91
                        • Aug 2010
                        • 3583
                        Get the M801a tuner.
                        Not sure about the power supply they sell them on ebay for about 7 quid so compare.
                        Andy.
