Error in display DM800
  • westkill
    • 2378
    #16
    where did you buy it from m8
    • shaks08
      • 37
      #17
      anyone found a solution for this, i have a clone and stuck with error on box display also cant connect to dreamup.
      is there a way to jtag these boxes
      • mariusclaudiubn
        • Sep 2009
        dm 800 hd
        hy , my problem was the same , the sim have bad connection , the case of the sim was broken .try to fix that and the box will work withouth to flash the firmware again .
        • piracyuk
          #19
          i had the same problem i fixed mine tho by swapping the sim card from a previous old box that was working but gaind a video fault. i took the working sim out of that and put it into the box that would not flash then it booted fine after wich i flashed open pli and all was good after that.
          • B2K420
            • Jan 2012
            • 12
            #20
            Originally posted by red devil
            Hi m8, had the exact same problem with a clone 600 (wit a clone safe image)
            apparently the 2nd stage bootloader on the internal sim is dead so no response after flashloader, was tryin to locate a sim to buy but no joy
            last resort is press connect on dreamup and try pressin down on sim when u reconnect power and keep it pressed until u get to flash
            red devil: You saved my life. I didn't use my DM800S-HD Clone (Sim 2.0.1, ssl#76) for 2-3 months. I switched it on after that time and came across the Nightmare Error called "Dream Multimedia Error". I tried everything then I followed what you said about pressing the sim as result I was able to install a bootloader and an image, now it is all working fine. Life is good. Thanks very much once again.
