800 HD PRO AUTO UPDATE
  • mial
    • 231
    Hi i have sgtflipflop bouquets set up i would like to put plugin autoupdate bouquets on box if i do-- do i lose the way bouquets are set up now ie all number and set in groups sport -movies-etc , also do you send it to box using dcc like i did with sgtflipflop update or is there a step by step guide availiable (have looked cant find one ) and is this the latest auto update prog---
    enigma2-plugin-extensions-autobouquets-e2_201209301945_all.rar --- would appreciate any help thank you mial
  • southpaw
    • 2233
    yes it puts it in same format as flipflops, after configuring it and running it you will be left with 2 set of bouquets (flipflop and new auto ones), you can then manually delete the flipflop ones with remote control , get channel list up (with down arrow)............ blue for favs...............select a category from flipflops .........press menu.......delete............do same for all other flipflop group entries . to get it on box you need to ftp the ipk file to temp then do manual install , method differs on different images or you can use dcc and select tools ..........ipkg packages...........upload package, this will install it and you only need to reboot unit
