Hard Drive Not Recognized on my DREAMBOX 800 running DreamElite Blackhole
  • JAMISKY
    • Dec 2012
    • 6
    Hi there
    So I initially had my box running on nemesis 2.4 but I had a few issues with it so I decided to change to Dream Elite BlackHole v 1.0 and it runs much better but now my hard drive is no longer recognized by the box . I had it connected internally and it worked fine previously but it was no longer being recognized , so I thought let me get a caddy and connect it externally but it still didn't work. So i plugged it into my laptop and formatted it to ext 3 with EASUS, i was going to use Gparted but this usually does the trick . Plugged the drive in and it lights up and theres a ticking sound but its still not showing up . I looked up some things on the internet and someone had a tutorial on how to make it work and it involved editing the fstab file , well just removing the # and that is what I did but still nothing.
    This is what it said:
    2. When you have opened it you will see something like this
    rootfs / auto defaults 1 1
    proc /proc proc defaults 0 0
    devpts /dev/pts devpts mode=0620,gid=5 0 0
    usbfs /proc/bus/usb usbfs defaults 0 0
    /dev/mtdblock2 /boot jffs2 ro 0 0
    tmpfs /var tmpfs defaults 0 0
    tmpfs /tmp tmpfs defaults 0 0
    #/dev/sda1 /media/hdd auto defaults 0 0
    3. Now remove the '#' so that it will be:
    4. Put the edited fstab file back in /etc, give it rights 644 and restart your box.
    The only thing is that I don't really get what rights 644 is so maybe it doesn't work because of that.
    If anyone could help that would be great.
  • bear1009
    • Feb 2013
    • 8
    go to menu, set up/system/ network/network browser/ press ok and you see your box with ip, select and expand it. you will see your hard drive. press ok on it( no add user name and pass word). you will see something like use as replacement hdd turn it to yes. press ok. (network will activate) reboot and see if it will work try this it worked for me ,sorry borrowed this from another site
    • bear1009
      • Feb 2013
      • 8
      sorry just noticed how long ago you posted
