LraiZer auto bouquets
  • mrblue
    • 568
    Ive downloaded this plugin to update my channel list automatically but it doesnt seem to be working on my solo running vix 2.4...i thought this plugin was for all e2 boxes,,,,
  • southpaw
    • 2233
    probably best to post your q in the dedicated thread for it mate, also a little bit more info on what the box does/says rather than just "its not working" will help those to help you http://www.digital-kaos.co.uk/forums...e-plug-296869/ , btw- awesome plugin when it works so stick with it
    • nush
      • Oct 2008
      • 178
      the vix feeds has the autobouqets plugin in it that works fine for the image
      • mrblue
        • 568
        I've got the plugin working and it does work well but still a few things I would like to know if I can change...
        1. The new bouquets did not overwrite my existing bouquets, do I have to delete old list manually, initially I had hoped the plugin would update my existing bouquets but if that's not possible I suppose I can get used to the new formation.
        2. The new bouquets title have spaces and full stops at the start, ie .. .. Entertainment, why is this, I know how to edit the folder name but will a further update change it back.
        3. Again, if I'm using these new bouquets there is no Irish bouquet or favourites, if I make these will they remain and be updated.
        4. Basically my main hope is that changes I make to the bouquets will still remain after further updates, will this be the case
          You will have to delete your existing bouquets so that the Plugin can create a new one which it will update for you when you choose to do so, you can edit anything in the plugin but best to have a look at the thread to see how its done as i know some memebers have changed it for different regional channels and so forth
