hello all
while i was searching for an answer i found that this forum stands out, with most questions replied and all. i hope that i can find my answer too.
well i have a dm800 hd pvr(clone), and just because i am curious i flashed the ssl84b over my ssl76. after a reboot without installing the proper image for the ssl , i had the error no ca found. i tried dreamup but it did not work. after uploading the flash script the machine boots to no ca found before the flash button is enabled. i found out that yassinov's ncf repair tool(2.5) was good for this job so i gave it a try. i tried all the available ssls on the software but after it says it's done it reboots to ncf state again. i was able to connect to the web interface after it finishes whatever it does and it was displaying ssl59, just for that time being i suppose.
so after that i have optiflash tool by the same guy a try. i tried the recover from ncf and update bootloader options with a proper ssl for the device. well it did update the bootloader, at least that is what i saw over the no ca found error. i tried to update to lower versions(down to 75). and i also installed a ssl84b image to get it working. it flashed ok , but no ca found was still there.
so here is the long sad story, i m stuck, can't watch my premiere league history channel, cant see the male lion's balls under the sun(just can't shake it out of my head-disturbing) . i hope you guys can tell me what i am doing wrong.
thanks in advance.
thanks in advance.
