Dreambox DM800 HD PVR will not boot and shows ***STOP*** dhcp...
  • bimoo
    • Jun 2013
    • 13
    #16
    yes
    Originally posted by southpaw
    You flashing with wired connection, not wifi and not homeplugs?
    Yes. only wired connection
    • blueflash234
      • Mar 2009
      • 904
      #17
      normally when you put a new sim in, you would flash a image for sim 2.10 when that is done do not reboot, switch off the box unplug it and then put your new sim in and then reboot the box
      • southpaw
        • 2233
        #18
        make sure the "on" power switch is not jammed or wedged in as this will give same symptoms with the box not booting, if all is well with the switch, then you could try and flash it with a image that's small in memory size, openpli or newnigma are small (44mb) , make sure you tick the button on web flashing interface to "reboot when complete". lastly if that don't work you can try with dreamup or optiflasher, both have an option to "recover bad sectors" tick it, you will need a null modem cable for this method. I am presuming the sim is not the issue as your box is getting as far as the web flashing interface, if it was sim related you would get other symptoms like "ca error", hopefully you somehow manage to get it going, report back how you get on please
        • gji25
          • Feb 2010
          • 353
          #19
          try selecting the correct image for your box
          dm500hd -dm500hd v2-vu+duo- triax 1.1m - inverto lnb - technomate 2300 motor- linksys ddwrt router
          • southpaw
            • 2233
            #20
            Originally posted by bimoo
            What should I do?
            maybe rather than start a new thread you could use your other thread, the last post were I made some suggestions and asked you to politely reply how it went http://www.digital-kaos.co.uk/forums...30/index2.html
            • digicon
              • 8261
              #21
              Now merged back with the original
