DREAMBOX 800 HD PVR (ORIGINAL NOT CLONE).......No CA FOUND error message....
  • lefteris62
    • Mar 2009
    • 7
    Hello....I'm getting the message: "Sim 201 team#84B www.dm800sim2.com --->error! *err01: No CA FOUND" on the panel of my ORIGINAL DM800 HD PVR....it doesn't accept me to re-flash it as it is not giving an IP address on the panel (when I keep pressing the front button and re-plug it)...what should I do to get it back in life? Can someone please give me step by step instruction? also proposal for a new stable image? thank you
  • andy91
    • Aug 2010
    • 3583
    You have flashed the box with wrong image/bootloader for your box. I put money on it that the box is a clone anyway. You will need the patched version of dreamup and a null modem cable. Lots of threads on this if you search and a couple of tools that will fix the problem. Main thing is to flash with correct image next time, Andy.
    • lefteris62
      • Mar 2009
      • 7
      thanx for your reply.....it is an original one....not only because I paid 450 Euros for it, but also a technician who opened it, saw the differences inside compared to a clone.....but again, these days you can never be sure, right?
      • andy91
        • Aug 2010
        • 3583
        Fair enough but you still need to do what I said. In the search bar put in No Ca Found you will find loads of threads on this. Patience is the biggest key as the box might not respond at first. Helps if you do it with a desktop pc with Windows xp and null modem cable and dreamup. Andy.
        • lefteris62
          • Mar 2009
          • 7
          Andy thank you...I bought a USB-to-RS232 cable and using DreamUp, after many tries, I was able to start the box and also found an image that works....but not as it was working before....because I can not find the normal Dreambox menus....no blue button functions, and the yellow, green or blue boxes in various menus contain nothing....is it a matter of image? (I haven't tell you the whole story: Last year I changed the original 2.01 SIM card of the box with a 2.1 FERRARI and installed a Nemesis image......a week ago after a simple restart I made to the box, it refused to work again...I took it to a technician who diagnosed that the SIM card was burnt and so we re-installed the 2.01 SIM)...do you have another image to recommend?
          • southpaw
            • 2233
            You say it's a genuine dreambox with sim201 , dream multimedia didn't use cheap Chinese sim201 so as Andy pointed out above it's a clone, if its got a Ferrari sim in them you need Ferrari clone images, if it's sim201 you need 201 clone images, if it has a genuine sim then you need genuine image,
            • benny/9
              • 1964
              also all genuine dreamboxes have the simcard holder
              sealed with a dark resin glue and it's very tricky to get the
              sim card out without damaging the holder
              Please Read Carefully!
              • andy91
                • Aug 2010
                • 3583
                Simplest image to use is Dream Elite Black Hole Phoenix Edition with the Ts Panel built in. Easy to navigate around. Open Pli image is pretty simple as well but I like the black hole image better, Andy
                • lefteris62
                  • Mar 2009
                  • 7
                  exactly...he who installed the sim 2.1 Ferrari card broke the holder....fortunately enough it still does it's job!!!!
                  • lefteris62
                    • Mar 2009
                    • 7
                    thank you for your help, I found solution and now the box is working
                    • andy91
                      • Aug 2010
                      • 3583
                      Always nice when a member tells us what his problem was for future reference, Andy.
                      • android325
                        • Aug 2013
                        what was the solution now?
                        • lefteris62
                          • Mar 2009
                          • 7
                          I apologize for not replying after so many days....I only found which loader is adequate to my box and also found an image that works too...which is the Nabilo Black Hole 0.12thank you for your help
                          • ISingh
                            • 4
                            I got the same problem with original box will you guide me to solve this??
                            • ISingh
                              • 4
