Help Updating Channels
  • toe471
    • 254
    Just wanted to know the best and easiest way to update the channels on the Dm800se?
    This is how I do it at the moment......Basically I have an freshly scanned channel list from the box and have this opened in the dreambox edit now i also open another dreambox edit (2 programs opened up) then find the modified channel and transfer it over to the channel list? I know it sounds a bit daft but this is what im use to doing?
    there must be a better way of doing this guys or you may even be able to change the freqency numbers in dreambox edit without doing a scan all the time?
  • andy91
    • Aug 2010
    • 3583
    Have you tried a channel list like Catseyes? Regular updated and if you need to update the odd channel do it with the remote control, Andy.
    • digicon
      • 8261
      If your just using 28.2? east then this is right up your street: http://www.digital-kaos.co.uk/forums...e-plug-296869/
      • toe471
        • 254
        Yeah its 28.2E list and im also using SGT List, I mite have a bash at using the Autobouguets plug-in, Im sure you can download it through the TSpanel section?
        • andy91
          • Aug 2010
          • 3583
          You can it also will put your regional TV but I like the layout of Catseyes bouquets, you can find it in downloads or in the bouquet section in the sat section.http://www.digital-kaos.co.uk/forums...7/index22.html Andy
