Hi there, I've installed some plugins in my DreamBox 800 HD PVR from Ferrari, when I restarted the machine to see what the boot-logo (Rihana) looks like and also to activate the other plugins , it did not re-boot or connect. I was told to flash it which I tried several times. The problem is that I don't know which image to choose and how long does it take to flash. Last night I left it to flash when I woke up in the morning it was still at the same point (neither uploading nor flashing). I also tried Dream-up it did not work for me. What would be the problem or what can I dod to reboot my machine ?
How long does it take to flash a DreamBox 800
Should take mere minutes through the web browser method and not more than half an hour through dreamup ... I'm from Singapore and looks like u r from UK but these timings are universal
Did the image upload go well? -
u are on Ferrari sim. only use image with Ferrari patched
Ferrari image can be found at their fourm and most of member here are using sim2.1,a8p... etcLast edited by uu161; 18 August, 2013, 09:18.if you like the post use the Like button located bottom right corner of each post
if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanksComment
.u are on Ferrari sim. only use image with Ferrari patched
I've tried several images including 'Ferrari-SSL82F-OpenPLi-2.0-beta-dm800-20110705' am still not having any luck. I've noticed that a lot of people are taking about using the right image, so I will keep on trying other images until the right one is accidently picked.Comment
Just make sure you only use images for Ferrari and not sim2 as you will semi brick the box. Flashing takes minutes with web browser method, Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
Also guessing with you being from UK its a sat box and not cable? Might get more help if it is a sat box and if it was moved to dreambox sat section, Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
When the box boots it will tell you on the oled display, if that don't show up take the cover off and locate the sim card. Only a few screws, Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
DM800 HD PVR not booting >> '/flash/vmlinux.gz'
Hi everyone,
I have A Dreambox DM800 HD PVR, it isn't booting on the LCD display is says ' /flash/vmlinux.gz'
I have tied flashing the machine using so many different images, and after three days, I am getting nowhere. Can you help please?Comment
