DM800 can't boot into *** STOP *** mode. Corrupt flash?
  • galip91
    Hi all,
    I'm trying to put OpenPLi on my DM800 but it gives me the invalid image error. Which, according to gjstroom, is because you need to install ssl84b and then reboot before you flash the image.
    I do install ssl84b, but it never gives me the reboot option after it's done. Not in the browser, nor DreamUp. In OptiFlasher when I check 'Reboot after done' it gives me 404 not found error after flashing the bootloader.
    So I guess this means the dreambox reboots by going to a special webpage (192.168.x.x/reboot maybe?). But my dreambox doesn't have that page.
    The weird thing is, that when I hold the power button when booting it doesn't stops when it shows an IP-address. It just goes on booting.
    Before it didn't even get an ip address from dhcp, I manually assigned one through hyperterminal.
    When I connect through DreamUp or OptiFlash it goes into *** Serial Mode *** instead of *** STOP *** mode. I've never seen STOP on my dreambox led..
    I managed to get the boot messages and I see a lot of errors/warnings. Is everything ok you think?
    dreamupd initialized
    Scanning JFFS2 FS: . done.
    find_inode failed for name=secondstage.conf
    load: Failed to find inode
    - failed to open /boot/secondstage.conf
    - failed to open /cf/autorun.bat
    lcd: /flash/bootlogo.elf
    bootlogo size: 184965
    *** BCHP: Invalid RTS setting detected. Forcing MEMC_0_CLIENT_INFO_7 (AVD_CAB_0
    ) RR to true. Please see latest 7401 RTS documentation.
    Supported modes: NTSC !NTSC_J !PAL_B !PAL_B1 !PAL_D !PAL_D1 PAL_G !PAL_H !PAL_K
    !PAL_I !PAL_M !PAL_N !PAL_NC !SECAM 1080i 720p 480p 1080i_50Hz !1250i_50Hz 720p_
    50Hz 576p_50Hz DVI_640x480p DVI_800x600p DVI_1024x768p DVI_1280x720p_50Hz DVI_12
    80x720p DVI_1280x720p_ReducedBlank !DVI_640x480p_60Hz !DVI_640x480p_70Hz !DVI_64
    0x480p_72Hz !DVI_640x480p_75Hz !DVI_640x480p_85Hz !DVI_1024x768p_60Hz !DVI_1280x
    720p_60Hz !DVI_1280x720p_70Hz !DVI_1280x720p_72Hz !DVI_1280x720p_75Hz !DVI_1280x
    720p_85Hz
    best supported mode is 18
    using 1920x1080i (50.00 Hz)
    HDMI
    using colorspace: 1
    *** BHDM: Waiting to transition to HDMI mode... 000CB001 0
    *** BHDM: HDMI Output Mode: HDMI (Audio+Video)
    create surface 1920 1080
    Using the Small jpeg decoder library, Copyright (c) 2006, Luc Saillard <luc@sail
    lard.org>
    parsing JPEG header..
    Virtual FB Size: 1280x720
    lcd: /flash/vmlinux.gz
    <5>Linux version 2.6.18-7.4-dm800 (linux@linux) (gcc version 4.4.3 (GCC) ) #1 Mo
    n Mar 28 08:46:47 CEST 2011
    Fetching vars from bootloader... none present, using defaults.
    board_init_once: regval=44ac6502, ddr_strap=3, 4 chips, pci_size=2
    Detected 256 MB on board
    <4>WARNING: read invalid MAC address ffffff:ff from flash @ 0xbffff824
    Default command line =
    root=/dev/mtdblock3 rootfstype=jffs2 rw console=null
    1 831ffebc 83029b34
    g_board_RAM_size=256MB
    Options: sata=1 enet=1 emac_1=0 no_mdio=0 docsis=0 ebi_war=0 pci=1 smp=0
    CPU revision is: 00020000
    Determined physical RAM map:
    memory: 10000000 @ 00000000 (usable)
    ---> memsize from bootloader: 148
    User-defined physical RAM map:
    node [00000000, 09400000: RAM]
    node [09400000, 06c00000: RSVD]
    <5>Reserving 108 MB upper memory starting at 09400000
    <7>On node 0 totalpages: 65536
    <7> DMA zone: 65536 pages, LIFO batch:15
    Built 1 zonelists. Total pages: 65536
    <5>Kernel command line: root=/dev/mtdblock3 rootfstype=jffs2 rw console=null
    before init RAC 0x02a00000 0x00000000
    after init RAC 0x02a0000f 0x0fff0000
  • southpaw
    • 2233
    correct method is this, 1 flash the image, 2, open a 2nd browser and flash the ssl84b file , then you boot box. do not reboot the unit inbetween , the ssl84b file must be flashed immediately over the image
    • galip91
      But I can't flash the image.. It gives me INVALID IMAGE OR OLD VERSION error when flashing te image..
      • southpaw
        • 2233
        Think that fault needs you to Use other version of dream up ,
        Google your fault code in " " to clarify
        • southpaw
          • 2233
          You have un zipped your downloads right? Both files should end in dot nfi
          • kakexi
            • May 2011
            • 4
            HI ! same proplem not get in box ! ill try in power off etc.. dreamup ALL VERSION ! not rj45 . my box opening very slow. Not opening tv, not response remonte control. What nex ill do ? i have JTAG but not more !!!
