DM800 IP Address Conundrum
  • dazmaul
    • Mar 2009
    • 61
    Hi,
    I hope someone can assist me because this is doing my nut in.
    I have a Dreambox 800 HD, using Engima 2, Gemini (not sure which version) - CCCam 2.1.0/NewCS 1.65.
    Whenever I do a Network Test it says that the IP Address is unconfirmed however, the IP Address is manually assigned and the DHCP is disabled. My router knows that it is an attached device and I can ping it. However, I cannot access the box through the web interface either.
    PLEASE HELP!
  • mcseadam
    just activiate DHCP by the box
    • dazmaul
      • Mar 2009
      • 61
      I've tried that but no joy.
      • dazmaul
        • Mar 2009
        • 61
        MORE INFO
        I have detected that my girlfriends laptop was causing an IP conflict with the Dreambox - I do not know why!
        I have shut down the laptop and the Dreambox has now started working but keeps losing its IP Address, one minute the router can see it and another it can't.
        Any help?
        • opsmonkey
          • 5379
          have you port forwarded your router..??
          In your LAN IP setup in your router config have you got:
          Use router as DHCP server
          ticked..??
          in the same config as above (LAN IP setup ) you can use Address Reservation and give your Dreambox a static Ip on your LAN
          • dazmaul
            • Mar 2009
            • 61
            I have tried at add an address reservation for the Dreambox but the device name appears as UNKNOWN and I cannot assign an address reservation to a device name as "UNKNOWN" - can I change the device name on the Dreambox anywhere?
            • dazmaul
              • Mar 2009
              • 61
              How do I Port Forward the router?
              • opsmonkey
                • 5379
                you should be able to name it in the settings.. something live this..
                check how to by looking here..
                Click on your router make & model
                Port Forward
                • dazmaul
                  • Mar 2009
                  • 61
                  I have assigned the Dreambox a static IP address in the router and it appears to have done the trick.
                  Thanks for the help.
                  • opsmonkey
                    • 5379
                    no probs mate
                    • paulie1972
                      • Jun 2009
                      This is really useful. I am struggling to get my DM800 up and running and have been trawling the internet to get things up and running. Whenever i find something useful it is invariably written by Opsmonkey. Good concise clear advice - good work fella!
                      • radioham
                        • 151
                        Port Forward
                        Might be just what I needed!!!Many thanks.Cheers Chas.
                        • southpaw
                          • 2233
                          i downloaded a hacked copy of "network magic" , when ever a device connects to my network , all info is accessed thru it , its proved handy for me
