Internal flash
  • elad
    • Sep 2012
    • 41
    Internal flash
    My internal flash is overloaded can I delete some things off it or will I have to re flash my box
  • digicon
    • 8261
    You can delete what ever you like better start with the plugin menu and see what you dont use in there to create some space, be careful though and stick with what you know is ok to delete and nothing else
    • elad
      • Sep 2012
      • 41
      It won't let me delete anything when I try it says not enough space left
      • digicon
        • 8261
        are you in the plugin menu and using Red Button to manage and then un-install some of the plugins
        • elad
          • Sep 2012
          • 41
          I went into ts panel to do it .... But I will try this way
          • elad
            • Sep 2012
            • 41
            Cheers for that I've done it your way and everything is fine now
            • davvo
              • Apr 2009
              • 666
              if your flash is getting full with plugins
              use a hdd or usb stick
              • blueflash234
                • Mar 2009
                • 904
                theres also a plugin flashexpander
