Hi. I'm using southpaw's OpenPLi 4.0 image and trying to change channel details using dreamboxEDIT. When I upload the new files, I might see the changed channel name once, but if I change channel and then go back it will have reverted to its original name. Similarly, if I download the files again I can see that modified package names have also reverted. Does anyone know why this is happening?
Channel name changes not sticking
not 100% sure as I personally use autobouquets and am happy with the default for my region. Are you saving the changes you make ? (in DBE press file > save) . furthermore if its just a few random channels then you can use the remote of the dreambox, (press down arrow to get to your channel list > then "Menu" on remote), should display a few options for rename/move/delete etc . Just beware the image has autobouquets schedules to run, so it may well over-write any user changes back to default , good luck !
