DM800 Not booting
  • art15t
    • 11
    DM800 Not booting
    My first post for help so here goes
    I thought I'd try out the latest pli image for the dm800 and the flash said all was successful but now the box get's as far as this:
    (c) 2007,2008 Dream Multimedia GmbH. All rights reserved.
    Dreambox DM800
    FIRST STAGE 1.00 {BO23456}
    2ND STAGE OK, build #73 (20090612)
    0.000 - BCM board setup
    {00000126,00000126,00000125,00000124,00000123,
    I've tried flashing it back to the Gemini and also the Nabilo but it still only gets as far as above. Any help or ideas would be greatfully appreciated. TIA
  • Curious123
    • 2591
    If your DM800 is a clone than you might have problems loading the latest Pli image. Try flashing one of the older nabilo images to see if it works.
    • art15t
      • 11
      Sorted
      Thanks M8. I hit it with an older gemini and it worked a treat!
      Yo the man!!
      BTW:
      Just in case someone else has the same problem. The Nabilo you require is mentioned here:
      h__p://www.nabilosat.info/forum/attachment.php?attachmentid=65556&d=1230574689
      It's the Nabilo_DM800_PureFlash29DEC08.zip with Barry Allen 4.6.52 built in. TY again Curious123
      • .: JaCkPoT :.
        Retired Sat TV Addict
        • Aug 2008
        • 5607
        I take it your box is a clone then mate!
        ___________________
        In the good old days, I had
        DM800s HD
        Openbox S10
        TM500
        DM500s
        90cm FortecStar dish
        Maxx 110cm Dish
        Technomate 2300 Motors
        • opsmonkey
          • 5379
          post clocking... state the bleedin obvious JP
          • art15t
            • 11
            Clone 800
            Yep I bought a batch direct from China and if I may say so the build quality is very good. I dropped a 160Gb HDD in one and originally I mod'd the fan because it was too noisy for the missus's liking but thanks to westkill's advise I ripped that out and now use a usb laptop cooler matt instead ...nice and cool and ultra quiet.
            So now I have it running via Nabilo_DM800_PureFlash29DEC08 and Barry Allen with the latest Pli image
            Thanks all
            • hs8kic
              • Sep 2009
              how can you flash
              Yo the man!!
              BTW:
              because I unable to connect to DM800 what ever which way.
              LED still display text "DREAM multimedia" and when use hiper-terminal is freeze on
              Dreambox DM800
              2ND STAGE OK, build #74 (20090820)
              and can not connect to for flash anymore
              Pleae help!
              Thankyou
              AOM
              • Jekkaman
                You have to flash your image and then flash a previous second stage version that your receiver suports.
                • wmccull
                  • 67
                  I used nabilosat blackhole v11 on ym dm800 Clone. It worked a treat no issues. and easy to configure. My biggest gripe about Pli-jade dm800 image is :- Its nothing lik the dm500 menu system ! why would they create totally different images , the answer is beyond me
                  • ramky
                    • 4
                    see this :
