dm800 se Help
  • davyk
    • 35
    dm800 se Help
    I?m not sure what sim I have or images I can use, can some one point me in right direction? (it?s a white sim covered with a black resin so I carnt read what sim it is)
    so far I have this info: -
    Its an original dm 800 se,
    from front led : - #84 x3.2 dm800se 9z
    Enigma2
    Dvb modules -2.6.18-7.4- dm800se-20120706-r0
    Linux version 2.6.18-7.4- dm800se
    Second stage dreambox-secondstage ? 84-r0
    Chipset: unknown
    Frontprocessor Version: 3
    Software
    Kernel version: 3.2
    Firmware version: 2014-03-29 19:06:37
    Gui version: 2014-03-26
    Tuners
    Tuner A: Alps BSBE2 (DVB-S2)
    I have used DreamUP_1_3_3_11 to install images onto box but the only two that don?t give the no ca error so far is:- release-dm800se-3.2.4(1).nfi and OpenPLi-4.0-beta-dm800se-20140326.nfi
    From the above info is it possible to tell me what sim I have and what types of images I can use before my head explodes thanks.
  • southpaw
    • 2233
    i have googled "OpenPLi-4.0-beta-dm800se-20140326.nfi" and it comes back as a sim2 84d image. to confirm this check the small screen on the front of the box as you apply power, it should read some reference to "sim2"
    if thats the case you can then flash any sim2 84d image , if you want older images you may need to downgrade your bootloader to 84b or earlier but personally i would leave it at 84d as thats the most uptodate, and just go with sim2 84d based images
    • davyk
      • 35
      Hi thanks for quick responce, i can't see anything about sim, just #84 x3.2 dm800se 9z. and my bootloader is secondstage 84-r0 would i need to change this to 84d? thanks again. also would the image i use have to be for original dms or could i use clone images aswell?
      • andy91
        • Aug 2010
        • 3583
        Good chance your box is a clone. If its sim 2 just find an image and if its 84d flash the bootloader 84d nfi before you flash the main image.
        Would recommend Openpli images.
        Andy.
        • davyk
          • 35
          i bought the stb as original off ebay (not a dealer or as new) i done the authenticity test and came back as original and i think the 2 images i had working were for original dm's? if this is the case could i use clone images or just original? and bootloader 84 r0 would be ok with 84 d?. im a bit of a noob with this stb but once i know exactly what box i have i can learn more about this box and e2 thanks.
