HELP ... No boot after flash - DM800 HD
  • abualferas
    • May 2010
    • 18
    #31
    Armandx
    Please share your solution with me and the others how have same problem
    • bubbles69
      • Feb 2010
      • 1150
      #32
      All solutions are for NO CA..!! and i have posted many times the working solution for NO CA
      • cunny
        • 4915
        #33
        Maybe a sticky is in order then bubbles?
        • bubbles69
          • Feb 2010
          • 1150
          #34
          Quick tut to repair NO CA on all DM800HD
          Please use patched version Dreamup here
          RapidShare: 1-CLICK Web hosting - Easy Filehosting
          1. connect via serial using NULL Modem cable and Ethernet to router and pc..
          if you don't have one you can purchase here null modem cable found here...
          EDITED . GOOGLE
          2. load patched version of dreamup, click connect and power on dm800
          3. when initialised it will display http serial mode on lcd ans show dhcp ip once ip is displayed dreamup as served its purpose and now its in flashmode
          4. log into webshell on pc using the 192.168.x.xxx address on LCD disply and flash as normal
          @ mod Please sticky this i have made a new thread so it can be sticky
          • barabulea
            • Oct 2011
            hi, is that box working in the end?
            • forgewire
              • Mar 2012
              dreambox 800 from dreamboxonline.co.uk
              I also bought it at dreamboxonline.co.uk. The box stuck while booting from new.We restarted it holding its front button to get ip address, it was fine, but the box didn't respond to any attempt to access it via browser.
              Apart from that the box doesn't look new.
              I wouldn't recommend to buy from this site, unless you want to pay twice to get a new one after.
