New at Dreambox DM800HD SE! MANY ERRORS! Please help
  • Thrillofit
    • Oct 2014
    Hello all!
    I Just started off to buy a dreambox DM800HD SE, I had before a DV8800 HD PVR i think which works fine but i needed a new one. So it started by i had to choose some hotbirds or thor and something like that and for some reason i couldnt get my channels on it so somehow i looked it up in google and had to change a satelittes.xlm file which i did and after i rebooted it asked to upgrade a firmware which I did and it just didnt boot anymore, it came up to 50% and shutted down. So i had to flash it which I did but now im getting a No CA found... So i downlodaded things like Optiflash, NCF, Dreamup and it cant find the dreambox. I have internet cable on it + USB from computer to dreambox aswell and im kinda new at this so i really need help to get it work. so please help me out!
    And im sorry, maybe i didnt post it right here but i didnt knew where else it should be.
  • piopat
    • 708
    no ca error means that when you reflashed you used an image (the tv software ) thats not suitable for your box . always before you flash a box find out what bootloader version and sim card version it is . to find out power off your box via the switch at the rear, then power back on , then look at the front lcd display and it will display various information including your bootloader version and your sim card version . this info displays quickly so you may have to do this a few times to read it .
    your sim card may be sim 2.10 , but you will see by looking at the lcd display . bootloader versions (OR BL versions ) can be different on different boxes depending on their age . older boxes may for example say BL75 or BL76 , but newer versions may for example say ssl84 . but once you have these two bits of info find an image suitable for use with these sim and bootloader versions and then you should be able to flash ok .
    i love it when a dreambox comes together.
    • WOODWARD395
      • Apr 2010
      • 628
      You may need these files if you have no ip address there is a pdf file you will need to follow all files are included.
      DreamUP_Patched_dm800_clon.zip
      Education is not the learning of facts, But the training of the mind to think
      So hit the thanks button if I have enlightened you.
