cloud ibox 2 plus buckup
  • fudge1
    • Jul 2014
    • 22
    hi guys i take no credit for this post as iv taken the post off anther site and use at own risk me or digital kaos take no responablity for your box thanks
    Backup of modded Vix Apollo 078 12/11/2014 Cloud ibox 2+ safe.
    Works on box's with 05/08/2014 Bootloader flashed to them (most new boxs these days)
    Bootloader available online google it
    IF THE BOX STICKS ON BOOT AFTER [COLOR=#1B8EDE !important]FLASHING YOU NEED TO ROLL BACK TO OLD 29/5/14 BOOTLOADER AND USE THE VIX 022 IMAGE. BOTH ARE AVAILABLE IN THE DOWNLOADS SECTION.[/COLOR]
    If ur remote wont work after flash it means ur running an outdated bootloader. See in downloads here for newest.
    There are (v few) clones of ibox 2+ out there but ask to be sure bootloaders are ok for you if you think its a clone. (Or remove five case screws. If boards say air ddt and no made in korea on case you SHOULD be good)
    ( If you have 2 usbs even better but not necessary. Ones going to live in the box permanently. Minimum 4gb for streaming to work correctly. Much easier. If you use that already just keep and use again in same way after flash. But cant be used for flash without pc format)
    (If the box boots up without flashing you either have old useless bootloader and need to update or usb issue so ask in forum for help :-)
    so first use ur fat32 formatted standard usb to put the cloudix folder on.
    turn off box
    insert flash usb in rear
    boot up. Box should take 3-15 minutes to flash and MAY say done on front when flashed. occasionally when flashing the front panel may remain blank, just give it 15 minutes in case. IT MAY STILL BE FLASHING.
    turn off box and remove usb
    now before rebooting insert ur pre-initialised usb
    or follow paragraph on right below. if using same usb as flash MAKE SURE AND DELETE FLASH FOLDER OFF BEFORE INSERTING AND REBOOTING.
    1st to initialise your drive AFTER FLASH (make sure cloudix folder is not on usb)
    Insert usb in back
    Turn on
    Menu
    Setup
    System
    Storage devices
    Initialisation (select ur usb/hdd)
    Initialise with red button
    Now Check
    Menu
    Setup
    Vix
    Mount manager (make sure mount is to hdd and format ext4)
    Now I always reboot to be safe but dont think necessary
    Menu
    Setup
    Vix
    Swap manager
    Make sure its created, enable at startup and active- or see setup thread.
    (Just change provider in service searching/ autoboquetmaker to your local and add ur u now what
    auto bouqets setup
    cross epg setup to hdd
    service scanning set to SD
    256mb swapfile setup
    Added SkySkin and Blue HD skin to vix dark skin
    Includes BackupSuite, mediaportal, ondemand, tsmedia, tspanel, dreamexplorer, OpenWebif, Picture player, Media scanner, RuYa IPTV, XBMCAddons.
    TSMedia as best as i can get movies for now but all hit and miss as usual file in download section
