DM800HD Error1
  • alfiezuk
    • 21
    DM800HD Error1
    Hi to all
    I flashed my DM800HD Via web brauser after sucsesfully completed the insalletion the NabiloBlackHole_DM800_011G it said ERROR1 NO CA FOUND.
    Any one can help me with this problem.
    Many thanks
  • opsmonkey
    • 5379
    my advise is to erase the image and flash a trusted 800 image from our download section
    • tegster
      • Aug 2009
      I had exactly the same problem. I solved it by connecting a null modem cable and using dreamup to connect to dreambox. Once connected you should be able to flash a different image using your web browser.
      • Naagendra
        • Mar 2009
        Hello All
        I am facing a problem on startup of DM800.
        An error is showing on LCD "NO CA Found".
        I tried with dreamup but box is not showing connected.
        I tried many versions of Dreamup.
        original to patched, 1.2.1.5 to 1.3.3.7 but nothing shows on dreamup when I plug in the power of the DM800.
        I searched on net, there are many ways but not working any way coz DM is not showing connected to Dreamup.
        Dreamup give the same message "Connection prepared, now switch on the dreambox!" after power on the DM.
        Pls any body have a good solution?
