DM800 No lights on front
  • martyok
    • 16
    I'm a bit of a novice but decided I would have a go at changing the fan on my DM800 which I managed ok. However when I have plugged the box back in there are no lights on the front display and no signal at the tv. I have checked the obvious things like connections etc (the fan is working incidentally) Could this just be coincidence or is it possible that the box has died. It has Enigma 2 installed. Is it possible to re-flash the image without the power as described/
  • thefantom
    • Dec 2010
    • 46
    You could try to re flash but it sounds like you may have shortened something. Take the fan out and try if it's still not working, power down and power up holding the power button whilst connecting. A IP address will show on the front - use your browser to connect to this.
    • deffc0n
      • Aug 2009
      • 894
      First disconnect fan and check box started if all ok check pins solders fan.
