mfaraj57,
The test I made was to instal the .nfi file in a USB pen by means of Barry Allen. Everything seems to work fine.
I did not instal it in the internal flash yet. If you tell me you found problems I would try.
There is one thing I believe you should take care of: you should use the same secondstage you have in your original flash. (I hope it would not be too late for you..).
If you do not know which secondstage your flash is using this is the procedure to find out what it is:
1) switch off the box. (deep stand by)
2) unplug the dream from the power supply.
3) after 10 seconds or so, plug it in again while pressing the front panel button.
4) keep the button pressed until you see "STOP" in the front display.
5) Immediately before seen STOP a string appears for less than one second on the last line of the display. If you read carefully that line, you should understand which secondstage you are using. It is a number in the range #61 and #74.
Good luck
Good luck
