Sky sports Uk channels tunin fail
  • temmy
    • Nov 2010
    • 11
    Hi guys, can anybody help with sky sports uk channels 1-5 on DM500HD, it works on open openbox all the sky sport channel 1-5.
  • 00360362878
    • Mar 2010
    • 488
    probably easiest way for you to sort it.
    perform a full satellite scan. Not sure on your munu so I will assume it is the same as the 800
    press menu>setup>service searching>Manual scan
    tuner as is
    type of scan single satellite
    satellite asta 28.2E
    rest as is
    hit green
    it will take 20mins ish
    then go into your channel list and you will access you fresh scan there, replace your none working channels via the remote
    • temmy
      • Nov 2010
      • 11
      Thanks a bunch mate
      • cactikid
        • 12017
        plenty of channel movement will affect many boxes.
