DM800 B Allan help plz
  • mickz
    • 48
    Hi all,
    Just gpt to grips with DM800 over the last few months now decided to play a bit more.Installed BA a few weeks ago BUT without a USB Stick so it went to hard drive.
    Since then i have obtained a 2 gig usb stick but when i try to ibtsall again it says allready installed on h/drive.
    Do i have to remove all ref from h/drive or discconect and reinstall hopefully to USB.
    tHANKS FOR YOUR HELP
  • westkill
    • 2378
    delete all ref of barryallen on the hdd like you said
    put this image in the flash with barryallen built into it
    Digital Kaos - Downloads - Nabilosat DM800 Pure Flash 01JUL09, Barry Allen 4.
    after install it will go through ba setup it may install it on hdd again as your usb stick may not be mounted to box
    so if it does install to hdd again
    there is a option in barry allen menu,s to mount the stick some were
    if that went well, reflash the above image then it should install ba on the usb stick
    now usb stick is now sorted
    ftp your new image to MB_images which either is on /media/usb or /media/hdd
    even if ba installed on usb, MB_images is put in /media/hdd by default
    then back to ba menu to extract image to usb stick
    heres an image for ba
    Digital Kaos - Downloads - Nabilosat Enigma2 Black Hole - DM800 v0.11
    this should work
    • mickz
      • 48
      Thanks fot your help, is it normal to take approx 30 mins to reboot onto new image , cheers
      • westkill
        • 2378
        no it should only take about 3mins
        when you chose the image from the barryallen screen
